18 years agoSerDes 8-bit Swap
I'm using the Stratix II GX Serdes in Basic mode with 1600Mbps data rate and input clock equal to 80MHz for 16 bit data packet. In the receiving interface, duiring the operative condition, sometimes ...
18 years agoHi gee,
Thank you for your answer. I trry to explain better my issue. I send a 16-bit pattern but every 8-bit represent for me a channel (LS & HS from the antennas). So, I cannot send a known pattern to the Rx during the operative condition of the system cause I don't know if I'm receiving the correct pattern or not. have you any suggestion ?
