16 years agoSERDES 6.25Gbps ALT2GXB rx_freqlocked
Hi All,
I have two Stratix II FPGAs (in two boards) communicating through 20 SERDES channels (Basic protocol). Usually things work fine. When one of the boards is not connected, I expect that the SERDES CDR will not lock (to data) and should give out rx_freqlocked LOW. Instead what I see is intermittently the CDR senses data (may be noise?? or crosstalk as 4 other SERDES links are active) and gives out rx_freqlocked as HIGH. My question is, is there anyway I can use any output from the SERDES block to reliably sense that there is no connection and a valid signal? (by adjusting any parameters?). In PIPE mode there seems to be more control for signal detection. What about in Basic mode? Protocol - Basic I have enabled manual equalizer control RXVcm = 0.85 Eq DC Gain = 1 Term Resisitor = 100 ohms Thanks, El2 Replies
I think, that checking for valid 8b_10b codes based on rx_syncstatus and rx_errdetect should give a more reliable link detection. But also a simple on-delay for rx_freqlocked may be sufficient to filter false link detection.
I appreciate your immediate response. That was fast!!! Thanks.
I have not enabled syncstatus signal when creating the block. I will do that and check if that solves the problem I did check rx_errdetect earlier and found that there was no error (on particular byte lanes). Regarding delaying rx_freqdetect, seems like it is stable and high for a very long time, even though it should not be receiving anything valid, But I do a digital reset (after few us delay)if I find that there is no rx_freqlocked.
