18 years agoSDRAM Controller
Now, i am researching about SDRAM Controller Core.So o need some document its.Can you help me? Many thanks
18 years agoBut dqm is a internal signal.What will happend if i assign constant 1 to dqm?I read in specification, they said that: I a given dqm signal is registered LOW, the corresponding data will be written to the memory; if the dqm signal is registered HIGH, the coresponding data inputs will be ignored, and a write will not be executed to that byte/column location".
