18 years agoSDRAM Controller
Now, i am researching about SDRAM Controller Core.So o need some document its.Can you help me? Many thanks
18 years agodqm is used as (usually bytewise) enable signal. You only need it if a partial write is intended, e. g. whem you have a 16 bit wide memory but want to write single bytes without affecting the other half word. It's present in the previously posted refernece designs and documents but must not necessarily be used.
