SDI video output not working in CvP mode
- 5 years ago
Hi Chee pin and John
I followed the steps mentioned in section 7.5.2. Fractional PLL Recalibration of ug_arria10_xcvr_phy.pdf
I implemented the system console command sequence as below :
# Follow these steps to re calibrate the fPLL:
# Request user access to the internal configuration bus by writing 0x2 to offset address 0x0[7:0]
#::ist::write_tcvr_pll_reg 0x000 2
#Wait for reconfig_waitrequest to be deasserted (logic low) or wait until capability register of PreSICE Avalon memory-mapped interface control0x280[2]=0x0
#::ist::read_tcvr_pll_reg 0x280
#To calibrate the fPLL, Read-Modify-Write 0x1 to bit[1] of address 0x100 of the fPLL
#::ist::write_tcvr_pll_reg 0x100 2
#Release the internal configuration bus to PreSICE to perform recalibration by writing 0x1 to offset address 0x0[7:0]
#::ist::write_tcvr_pll_reg 0x000 1I do get the fPLL lock and SDI output is up and running successfully.
I really appreciate your suggestions
Piyush,
Piyush.
Hi Piyush,
Sorry for the delay. Thanks for your update. Glad to hear that you have managed to resolve the issue and your system is up and running.
