SDI video output not working in CvP mode
- 5 years ago
Hi Chee pin and John
I followed the steps mentioned in section 7.5.2. Fractional PLL Recalibration of ug_arria10_xcvr_phy.pdf
I implemented the system console command sequence as below :
# Follow these steps to re calibrate the fPLL:
# Request user access to the internal configuration bus by writing 0x2 to offset address 0x0[7:0]
#::ist::write_tcvr_pll_reg 0x000 2
#Wait for reconfig_waitrequest to be deasserted (logic low) or wait until capability register of PreSICE Avalon memory-mapped interface control0x280[2]=0x0
#::ist::read_tcvr_pll_reg 0x280
#To calibrate the fPLL, Read-Modify-Write 0x1 to bit[1] of address 0x100 of the fPLL
#::ist::write_tcvr_pll_reg 0x100 2
#Release the internal configuration bus to PreSICE to perform recalibration by writing 0x1 to offset address 0x0[7:0]
#::ist::write_tcvr_pll_reg 0x000 1I do get the fPLL lock and SDI output is up and running successfully.
I really appreciate your suggestions
Piyush,
Piyush.
Thank you Chee Pin for your response and provide me detailed steps to debug the fPLL lock
Followed below steps so far :
1. Try web case (workaround/fix): changed the QSF assignment to change the reset control from the Avalon-MM register to the pll_powerdown input: This did not help and still no lock when I toggle the pll_powerdown input
2.Implement Avalon-MM register Interface : Enable the dynamic reconfiguration interface and enable control and status registers and add custom Avalon control interface IP to access the fPLL registers. Update the fPLL block and make appropriate port connection and build the project.
Please review below settings and ports:
3.Try to reset the fPLL by toggling to fPLL reset register i.e. 0x2E0[0] , no change is observed in pll_cal_busy and pll_locked signals
Just to make sure I am correctly accessing the fPLL registers, I read few registers and get some default values, can you confirm if these values are correct
system console commands
% ist::read_tcvr_pll_reg 0x0
0x00000002
% ist::read_tcvr_pll_reg 0x1
0x00000001
% ist::read_tcvr_pll_reg 0x2
0x00000000
% ist::read_tcvr_pll_reg 0x3
0x00000000
when I write '1' into 0x2E0 command and read back I get the correct value
% ist::write_tcvr_pll_reg 0x2E0 1
% ist::read_tcvr_pll_reg 0x2E0
0x00000001
when I write '0' into 0x2E0 command and read back I get the correct value
% ist::write_tcvr_pll_reg 0x2E0 0
0x00000000
4. Next step is to try reconfigure the fPLL, Could you refer some documentation or steps for fPLL reconfiguration process ?
fPLL refclk and CLKUSR are directly sourced from stable and free-running oscillators on-board and they seems to be good because everything is working when CvP mode is disabled.
Piyush.
Signal tap Write/Read command Captures
Write command
Read command
No fPLL lock, so I will continue exploring the fPLL reconfiguration as suggested by Chee Pin.
Piyush.
- Piyush_Patel5 years ago
Piyush,
Piyush.
