SDI video output not working in CvP mode
- 5 years ago
Hi Chee pin and John
I followed the steps mentioned in section 7.5.2. Fractional PLL Recalibration of ug_arria10_xcvr_phy.pdf
I implemented the system console command sequence as below :
# Follow these steps to re calibrate the fPLL:
# Request user access to the internal configuration bus by writing 0x2 to offset address 0x0[7:0]
#::ist::write_tcvr_pll_reg 0x000 2
#Wait for reconfig_waitrequest to be deasserted (logic low) or wait until capability register of PreSICE Avalon memory-mapped interface control0x280[2]=0x0
#::ist::read_tcvr_pll_reg 0x280
#To calibrate the fPLL, Read-Modify-Write 0x1 to bit[1] of address 0x100 of the fPLL
#::ist::write_tcvr_pll_reg 0x100 2
#Release the internal configuration bus to PreSICE to perform recalibration by writing 0x1 to offset address 0x0[7:0]
#::ist::write_tcvr_pll_reg 0x000 1I do get the fPLL lock and SDI output is up and running successfully.
I really appreciate your suggestions
Piyush,
Piyush.
May I know if you are running the same board when testing the design? Could you share with me your Quartus Project for CvP so that I can further look into the issue?
- Piyush_Patel5 years ago
Yes, I am running the same board when testing the design. After entering into user mode, only SDI output doesn't work when CvP is enabled and rest of the FPGA logic works fine .
When building the same project without CvP enabled works just fine including SDI.
I will share the Quartus project with CvP enabled for your review.
Please find the attached CvP_SDI_Issue.zip for your review.
Project was build in Quartus 19.3. Please advice. Let me know if you need any more info.
Hi John,
I just wanted to follow up on the SDI project that I shared few days back.
Please review and see if you can provide any suggestions/workaround.
Appreciate you support.
Piyush.
