SDI video output not working in CvP mode
- 5 years ago
Hi Chee pin and John
I followed the steps mentioned in section 7.5.2. Fractional PLL Recalibration of ug_arria10_xcvr_phy.pdf
I implemented the system console command sequence as below :
# Follow these steps to re calibrate the fPLL:
# Request user access to the internal configuration bus by writing 0x2 to offset address 0x0[7:0]
#::ist::write_tcvr_pll_reg 0x000 2
#Wait for reconfig_waitrequest to be deasserted (logic low) or wait until capability register of PreSICE Avalon memory-mapped interface control0x280[2]=0x0
#::ist::read_tcvr_pll_reg 0x280
#To calibrate the fPLL, Read-Modify-Write 0x1 to bit[1] of address 0x100 of the fPLL
#::ist::write_tcvr_pll_reg 0x100 2
#Release the internal configuration bus to PreSICE to perform recalibration by writing 0x1 to offset address 0x0[7:0]
#::ist::write_tcvr_pll_reg 0x000 1I do get the fPLL lock and SDI output is up and running successfully.
I really appreciate your suggestions
Piyush,
Piyush.
May I know if you have try to reset the SDI IP and also monitor the SDI IP signal using SignalTap?
- Piyush_Patel5 years ago
Yes, I tried resetting the SDI IP but no luck. The ready status from Transceiver PHY reset controller ramains low (which is why I am not getting the SDI video output).
So currently I am monitoring other signals like PLL locked, cal_busy for PLL and transceiver PHY, just to make sure the calibration is done. I also have to make sure that the transceiver went through correct reset sequence.
I will keep you posted with more information soon.
Do I have to do something specific for transceiver calibration and transceiver reset sequence as far as CvP initialization mode is concern ?
After CvP initialization is Done, capture SDI PLL and reset transceiver signals in Signal Tap
1. When SDI is working (Without CvP enabled - programming normal *.sof) tx_ready is high and PLL is locked - see attached capture "Working Condition PLL Locked.JPG" and other signals are also in correct state.
2.When SDI is not working (CvP Enabled) tx_ready is low and PLL is not locked, digital reset is high from transceiver reset (may be due to missing lock input) - see attached capture "Not Working no PLL lock Digital reset high"
3. I verifed the PLL input clock (148.5 MHz) using oscilloscope, in fact I am using the same clock as sample clock in signal tap. I also try resetting the reset controller which drives the the pll_powerdown input, still not getting the PLL lock after de assertion of reset- see attached "pll_powerdown active.jpg"
It seems PLL lock is the issue, However, In all cases busy signal remains low ? does that mean the calibration is successfully done during CvP initialization?
Any thoughts ?? Thanks.
