9 years agoSDI Transmit Triple Rate on Cyclone V
Hello all, I'm having issues trying to get a triple rate SDI transmit only module up and running on a Cyclone V dev kit. I can get 1080P60 out working fine using a pattern gen as an input to the CVO...
8 years agoHi,
You can't let the reconfiguration interface unconnected. When switching the video standard from 3G/SD to HD or vice versa, it require the reconfiguration. Please refer to the following example design, I created this example to show case the CVO switching function and it use the SDI interface to transmit the data. This design should be useful to you. http://www.alterawiki.com/wiki/cvo_ip_video_mode_detection_and_switching_feature Best Regards, Terence (This message was posted on behalf of Intel Corporation)
