9 years agoSDI Transmit Triple Rate on Cyclone V
Hello all, I'm having issues trying to get a triple rate SDI transmit only module up and running on a Cyclone V dev kit. I can get 1080P60 out working fine using a pattern gen as an input to the CVO...
8 years agoHi Prushton,
You can't let the reconfiguration interface unconnected. When you switch the SDI data from 3G/SD to HD or vice versa, you need to perform the reconfiguration. The following example is I created to show case the CVO video mode switching with SDI interface. It should be very useful to your application. http://www.alterawiki.com/wiki/cvo_ip_video_mode_detection_and_switching_feature Best Regards, Terence (This message was posted on behalf of Intel Corporation)
