13 years agoSDI IP without driver/equalizer
Hello, I have a board without SDI-IO capabilities (no equalizer nor driver). But I can connect directly to Arria II GX transceivers BNC... Is is possible to validate a complete SDI bypass sol...
13 years agoWell, what speed are you attempting? SD-SDI, sure. HD-SDI, can still do. But you must really watch the return loss and loss at 3G-SDI. You will have better luck with a Shielded Twisted pair (Cat 6 or better), than using Coaxial, as the transceiver in/out are all differential.
