PVanL
5 years agoScripts from Quartus in Modelsim not using the latest files when compiling
I am using quit a while Modelsim (DE-64 2020.3), in which i change and add files to the examples generated by Quartus 20.2. So far successfully, in the sense, that Modelsim behaves as expected. In th...
Chris2000
5 years agoI'm having the same problem with 20.3.
Project -> Clean Project did not help.
\sim\mentor\common\modelsim_files.tcl does not get updated when I generate HDL or TB in Platform designer or compile the FPGA or Generate Testbench system.
What action causes this file to be created/updated?
RichardT_altera
5 years agoSorry for idling for sometime. Do you able to solve the issue?
Have you try go to Tools > Generate Simulator Setup Script for IP in the Quartus Pro? It should generate the modelsim _files.tcl for the IPs used.
- RichardT_altera5 years ago
Customer able to solve the problem and the problem is for some reason system created a library 'work' where the newly compiled version of altpcietb_bfm_rp_gen2_x8.v was, but in executing, it used /libraries/work, where a previous compiled version was.
