14 years agoSATA host IP for cyclone IV GX ?
Hi, I planning to develop a SATA interface to plug a SSD to save video sequences. I would like to use the cyclone IV GX family. I have found a development kit and a daughter card (cyclone I...
14 years agothanks ironmoose for your reply;
The reason we cannot do 8b/10b in the PHY is because our SATA controller already does it in the link layer. we would have to bypass the 8b/10b in the link layer in order to use the one in the ALTGX. I am using the FPGA to emulate an ASIC and the PHY in the ASIC does not have 8b/10b encoding. An Altere FAE told me that another customer had tricked the MW to provide the rx_signaldetect without selecting 8b/10b and it worked for them. So, I am thinking of trying that myself. The way to trick MW is to select 8b/10b and then select the rx_signaldetect port and then unselect the 8b/10b and the rx_signaldetect port remains there. I tried it in simulation and it does do the right thing. I was able to do the COMRESET/COMINIT sequence. Another question I have is how did you do change the speed of the ALTGX? The appnote recommends two methods. 1) have 3 mif files one for gen1, gen2, gen3 and then use the altgx_reconfig block to change the config of the altgx. 2) use the rate_switch_cntrl to change the clock divider to 1, 2, or 4 to change the tx clock. I tried method 2 which is easier to implement and it worked in simulation. skg
