15 years agoRound or truncate? 截取和舍入对滤波器输出精度影响?
turncat and rounding on the accuracy of the filter output? designing filter with Fpga, there are two output modes, turncut and rounding. What effect on accuracy on Both methods have? Is t...
15 years agoHi Kaz,
--- Quote Start --- I have been through dsp projects with/without rounding. The notion of dc unbiased version is relatively new. In most cases I had to please the rf engineer by removing a tiny speckle of dc in the spectrum centred on carrier frequency. --- Quote End --- It ends up being important if you do a lot of complex-valued baseband processing, since the quantization noise spike shown in the slides shows up the in 'middle' of your band. If you were only processed real-valued signals, then the DC channel is probably discarded anyway, so its not as critical. --- Quote Start --- I am however not clear about round() having positive/negative dc as in your slide. If you look at my table above then there is no way I can imagine dc bias as values are symmetrical around zero. However, I do have some doubts about why the stress has moved to convergent case. Any clarification appreciated. --- Quote End --- round() is interesting isn't it. There is no bias if you take all the data and perform a 'mean' on it, but you can see from the figure in the slide that the positive values of the signal have a slight positive bias, while the negative have a slight negative bias, due to the rounding of 0.5 values to the next whole value in magnitude, i.e., 2.5 rounds to 3, and -2.5 rounds to -3. Though, I'm not sure how you'd see this effect in practice. The convergent rounding operation is pretty simple to implement in VHDL, see the attached. Since its so simple, I just 'use it' :) Cheers, Dave
