18 years agoRGMII with the triple speed ethernet MAC core
Hello, I have a board with a Stratix II 180 C3 FPGA and a Marvell gigabit Ethernet PHY. The MDIO connection with the Phy works well. I can get the Phy status/id/etc. I also receive Ethernet pac...
14 years ago --- Quote Start --- I do no special setup of the Marvel Chip, because I also have no datasheet. The hint with the 90deg phase was the solution. I created a PLL for the 125 MHz signal. The 0-degree frequency goes into the TX_clock of the IP-core. The 90-degree freqency goes into the PHY GTX clock. Then sending of a frame succeeds. --- Quote End --- Does this work for non-gigabit speeds? My PHY is running at 100Mb and I am confused whether the clock needs to be delayed 90deg or a fixed amount of time. Big difference when switching between 125, 25, and 2.5MHz. Ideally I would like the ethernet port to handle all three link speeds. I am trying to get RGMII working on the arria ii devkit, and maybe this is my problem. I've also seen discussion of writing to a register in the PHY to let it handle the clock skew, but I have not seen and code to actually do this. Any insight into this matter will be appreciated.
