18 years agoRGMII with the triple speed ethernet MAC core
Hello, I have a board with a Stratix II 180 C3 FPGA and a Marvell gigabit Ethernet PHY. The MDIO connection with the Phy works well. I can get the Phy status/id/etc. I also receive Ethernet pac...
16 years ago --- Quote Start --- Yes, but remember the TSE MAC only works for RGMII Gigabit mode but not RGMII 10/100 mode for now. Information on setting the timing of RGMII interface 6.2.1 Receive Direction The FPGA can accept clock edge aligned input data by adding pin-delay to the data inputs ensuring proper DDR sampling. This can be achieved by applying negative hold-time constraints (e.g. -1.5ns) to the data input pins of the FPGA. If the pin-delay should not be used, alternatively the PHY can be instructed to add delay to its clock output pin by setting bit 7 of the MDIO register 20. To do so, the following procedure should be followed: • read register 20 • set bit 7 to enable rx clock pin output delay preserving all other bits • write register 20 • Issue a software reset to the phy to apply the change, by reading register 0 (CONTROL) and writing it back with bit 15 (reset) set to 1. 6.2.2 Transmit Direction A typical DDR output implementation supporting multiple speeds in RGMII will provide the clock edge aligned with the data edge. However, as the board does not implement a board trace delay, the clock needs to be shifted by 2ns to ensure proper timing at the PHY device inputs. This can be done by either implementing a corresponding shift in the FPGA, or by setting the integrated delay transmit option (bit 1) within the MDIO register 20 of the PHY. To set the transmit delay option, the following procedure should be followed. • read register 20 • set bit 1 to enable tx clock pin input delay preserving all other bits • write register 20 • Issue a software reset to the phy to apply the change, by reading register 0 (CONTROL) and writing it back with bit 15 (reset) set to 1. --- Quote End --- Hello, Can we apply these suggested steps on Cyclone III (C120)? Thanks
