Replacement for SDRAM controller after V16.1?
Intel has indicated that the Qsys component for the SDRAM controller will no longer be available for use with the free software after Quartus V16.1. If you try to instantiate a SDRAM controller (using Qsys) in 16.1 it warns of this in the comment box for the component. I have not installed Quartus 18, but have looked at an install and did not see the SDRAM controller. Have I been mis-informed?
- Fred_SAN1 year ago
For information , if your still use DE10-Standard (Cyclone V SoC dev board from Terrasic) as I do for a quick proof of concept design,
While recompiling old demo projects from Terasic for DE10-Standard, and in particular the SDRAM_Nios_Test as archived in the CD_DE10 (at this time generated under V16.1), confirm with Quartus prime lite V21, the legacy SDRAM controller generates an error, in revange with a fresh install of Quartus Prime Lite Version 17.1.0 Build 590, (downloaded April 2025) the QSys module still displayes as upgraded from 16.1 to 17., the initial SDRAM Controller: named "altera _avalon_new_sdram_controller " Version 17.1 and compilation is successfull with 0 Error.
Best Regards.
Fred
