Sai2403
9 months agoRegarding MIPI CSI 2 TX
Hi, In my Project, I have to generate test pattern data and send it to MIPI CSI 2 via AXI stream, and MIPI CSI 2 will send the pixel data to link_0 of MIPI DPHY IP , but when i try to simulate the de...
Wincent_Altera
8 months agoSai2403
7 months agoHi wincent,
we took reference from simulation, and had developed AXI stream interface to drive the MIPI CSI TX input, we observed that clock would be available for few cycles and will stop generating. Is there signal to indicate internal PLL has set properly, or any parameters need to enable to observe the clock ? we were able to see clock and data on dphy lanes in simulation but couldn't on hardware.
regards,
sai2403
- Wincent_Altera7 months ago
HI Sai2403 ,
Can you please share me your simulation result waveform (expected)
and HW waveform (fail)
That can help me better understand what you are seeing and provide a better future step.
Wincent - Wincent_Altera7 months ago
Hi ,
Is there any update on the waveform ?
Regards,Wincent
