Sai2403
9 months agoRegarding MIPI CSI 2 TX
Hi, In my Project, I have to generate test pattern data and send it to MIPI CSI 2 via AXI stream, and MIPI CSI 2 will send the pixel data to link_0 of MIPI DPHY IP , but when i try to simulate the de...
Sai2403
9 months agoHi wincent,
I think there is some confusion regarding this. I just used two available IP's (MIPI CSI 2 and MIPI D-PHY),
and have been driving the inputs of MIPI AXI Stream from test bench, apart from this there is not any Code I have used in the design.
Regards.
Wincent_Altera
9 months agoHi Sai,
There is a weird things to do if you just try the design via two IP.
Because the MIPI design cross related with other IP as well such as ISP , Frame Buffer and other etc.
To ensure its functionality and signal triggering.
IF you just want to purely run the simulation - I suggest to generate one from the design example.
You may get it from the IP catalog under Quartus. That could be a good start for you.
Wincent
