Reference Design RP to EP?
Dear Community,
I am looking for a small, well-explained example or tutorial for a very simple data transfer between a PCIe SOC HIP Root Port and an PCIe HIP endpoint.
I worked through this: https://rocketboards.org/foswiki/Projects/PCIeRootPort
and that: https://rocketboards.org/foswiki/Projects/PCIeRootPortWithMSI
But there are files missing and errors occur and the projects are not well enough documented to find the errors without too much effort.
My Dev Kits are:
- Root Port: Cyclone V SoC Development Kit (5CSXFC6)
- Endpoint: 5CGTFD9EF35C7, https://www.intel.com/content/www/us/en/products/details/fpga/development-kits/cyclone/v-gt.html
Best Regards
- EBERLAZARE_I_Intel
Can you check from your side if you can access the full design here:
https://releases.rocketboards.org/release/2015.10/pcie-ed/hw/
Do you have any update?
- Zarquin
Dear EBERLAZARE,
I can access the full design files from your link above.
But these seem to be the hardware files from the Rocket PCIe RootPort with MSI example I already have. (?)
The problem with the Rocket examples is that the:
- PCIe RootPort example is missing the hardware files
- PCIe RootPort with MSI example is missing the SD-image
I tried to combine the examples but without success.
Best regards
Unfortunately, you may have to build the Uboot and kernel after compiling the GHRD in Quartus, as demonstrate at the bottom of the page.
Do you have any further questions?
