RTL_FPGAs
5 years agoReed Solomon ii IP core simulation fails to compile in ModelSim
I was trying to simulate the Reed Solomon ii DECODER IP provided by Intel with Quartus Pro 20.1, but ran into a compilation issue out of the box. The IP core parameters are configured to gen...
CheepinC_altera
5 years agoHi,
Sorry for the delay. As I understand it, there is no compilation issue when you are using Verilog in the simulation. Just to check if you are able to use this as workaround to proceed?
