14 years agoReceived Packet Size Differ From transmitted TCP Packet
Hello Friends I have image transmitter who transmit Image in form of TCP packet (Server), This Server Send image toward NIOS_II based Client using TCP protocol, now Transmitted TCP packet Size...
14 years agoThat code won't work (as you've found out).
As I said, TCP is a bytestream protocol. The data from the send() calls will very likely be merged together then split into full sized ethernet frames. The recv() will be given a partial length if it 'catches up' with the receive data stream. If you put a marker at the start of each 640 byte block you'll find that you receiver is misaligned on the rx data for most of the trace.
