14 years agoReceive Transceiver clock recovery problem without loopback
Hi, I am working on a high speed optical fiber link between two FPGAs. Now the design seems to work perfectly in a loopback setting. But when I connect two boards together, download the ex...
14 years ago --- Quote Start --- >> However, none of the REFCLK signals from the transceivers route via the HSMC connector What do you mean? --- Quote End --- See page 46 of the HSMC specification: http://www.altera.com/literature/ds/hsmc_spec.pdf Connector pins 1 to 32 are defined as transceiver lanes, but there is no assignment for a transceiver REFCLK clock. --- Quote Start --- I think that clk2_p/n (figure 2.3 in the manual) is the clock that the design sees as the pair hsmb_clk_in_p2 and hsmb_clk_in_n2, which is then used as a refclk further in the code by the CDR (the code is available on the website too). --- Quote End --- That is possible, however, it would be a function of the DE4 board clock distribution. You'd want to check that documentation to see what clocks on the HSMC route to FPGA pins that can be used as REFCLKs. --- Quote Start --- What I did now is that I connected clk2_p/n (figure 2.3) from one board into the SMA_clk_p/n of the second board, such that the clk2_p/n of the second board is the same as the one from the first board. --- Quote End --- That sounds reasonable. --- Quote Start --- I am not sure if the mux that is pictured would create problems though (like adding a delay to the other clock), --- Quote End --- The delay should not matter. The logic levels of the clocks will. You'll need to see whether things are AC-coupled, whether they require termination, etc. --- Quote Start --- It doesn't work though... with this configuration there is no data sent/received by the second board. Either my connections are not what they should be, or the cables I am using aren't doing the job. --- Quote End --- Plug the cable with the clock into a scope and look at it. Use an oscilloscope to probe for the clocks around the place. Implement the clock counter logic I told you I use, and then count clocks. You can send a lower frequency clock around if you are concerned the cables aren't great; once you get things working, increase the clock rate and see if there are issues. Cheers, Dave
