9 years agoReal time FIR filtering MAX 10 FPGA Development Board
Hi, I am working at implementing a bandpass FIR filter on MAX 10 FPGA development kit. So, I am taking a signal input from the SMA connector into the ADC (1Msps, allowed input clock levels 2, 1...
9 years ago --- Quote Start --- The maximum as per data sheet is 1 Msps. The Qsys Modular ADC gives the mentioned clock rates. How can I down sample ? Could you point me to some resources? --- Quote End --- if your sample rate is 1Msps indeed you have no problem and you don't need downsampling. then your p/s convert will have sample rate of 1Msps at its input, 24 Mbps for DAC. You must sample your data at 1MHz at whatever clock you use (e.g. use clock enable)
