Unable to install kernel driver for testing PCI Express
- 10 months ago
Hi Embeddedesigner,
Thank you for the updates.
Device configuration is outside of my area of expertise.
Could you please file a new post in the forum regarding your configuration issue? The device configuration support expert will be able to assist you with this issue.
Ven
I want to close this thread as an acceptable answer, but I have encountered another more serious problem.
I will also go back and fix the updated kernal API drivers manually to fix the issue. The issue I'm having is actually programming my board, after I successfully generated the design example, compiled, set the .qsf file settings to the recommended pin assignments in the design example folder. It keeps stopping at 80% and outputs this error message:
Error(18950): Device has stopped receiving configuration data
Error(209012): Operation failed
Error(18948): Error message received from device: Device is in configuration state.
There is an internal Bug ID: 1508562679 that addresses this known issues with the Stratix10 fpga which states :
Resolution
This problem is fixed starting in Intel® Quartus® Prime Pro Edition Software version 20.4.
I have a running reference clock assigned, which is provided on the Terasic Apollo S10 SoM.
Can you assist in a solution?
