RHobb
1 year agoSimulating L-Tile and H-Tile Avalon MM+ Intel FPGA IP for PCI Express using Questa
I'm following the user guide L-Tile and H-Tile Avalon MM+ Intel FPGA IP for PCI Express and using Questa Intel FPGA Edition to simulate. This is for Quartus Prime Design Suite 23.4. I followed the p...
- 11 months ago
Thanks for the sharing of your conclusion and findings.
You're right. The simulation of S10 PCIe AVMM example design has problem which reports "FAILURE: Simulation stopped due to Fatal error!". After checked, the same issue exists in Q25.1 Pro as well. This is a bug that we need to fix.
Rong
RHobb
11 months agoCan you kinly provide your .IP variation file used to simulate the PCI Express core?
And what version of Quartus Pro are you using?
