Queries on 46.6944 Gbps PAM4 F-Tile Configuration and Loopback Testing using Agilex7
Hi Himanshu,
Thank you for following up.
I checked our internal database and found that the fgt_rx_signal_detect_lfps_port was originally intended for USB-related applications. However, the Direct PHY IP does not support USB mode. As a result, this port was removed from the Direct PHY IP implementation and is not exposed to users.
At present, there is no supported method to enable or access this port in the latest Quartus release. Sorry for any inconvenience this may cause.
Hi Himanshu,
I believe that your initial question has been addressed, I now transition this thread to community support. If you have a new question, feel free to open a new thread to get the support from Altera experts. Otherwise, the community users will continue to help you on this thread. Thank you very much.
