EBoln
5 years agomem_reset_n always is low from DDR3 hard controller
i have ArriaV, DDR3 chips, but after deassert global and soft resets mem_reset_n stay is low. Soft reset generate after 1000 tick on 100MHz clk
What else can affect this signal?
AdzimZM_Altera
5 years agoThanks for clarifying about your project.
I guess there is no error during the IP generating process and compilation.
But since you're facing some issue with the Arria V device, can you use the example design to simulate your IP in the Arria V?
EBoln
5 years agoI try to simulate... and all signals correct
- AdzimZM_Altera5 years ago
Great!
Can you check the connection between your IP and your design?
And compare it with the example design.
- EBoln5 years ago
I create new project with same qsys file with ddr3 controller
