AdzimZM_Altera
4 years agoCan you give it a test?
So before this you're working on Cyclone V device and it's worked.
But now you try to implemented it in Arria V is it?
Do you create a new IP for the Arria V or you use the existing project?
EBoln
4 years agoAnd i try create new qsys with controller
- AdzimZM_Altera4 years ago
Thanks for clarifying about your project.
I guess there is no error during the IP generating process and compilation.
But since you're facing some issue with the Arria V device, can you use the example design to simulate your IP in the Arria V?
- EBoln4 years ago
I try to simulate... and all signals correct
Great!
Can you check the connection between your IP and your design?
And compare it with the example design.
