[IP_Compiler for PCIe__Cyclone IV GX] How to start the chaining_dma example
Hi Christope,
Thank you for reaching out.
In your screenshot, novopt is deprecated in ModelSim 2020.1 and has no effect. You may try to fix for your version of ModelSim by replacing the -novopt in the vsim call inside runtb.do (around line 143) with -voptargs="+acc", which still enables full signal visibility while using the modern optimizer path.
Please note that the Quartus Prime 18.1 and ModelSim 2020.1 are not an aligned pair. We recommned you to use the ModelSim – Intel FPGA Edition that is bundled with Quartus Prime 18.1 (download from the Quartus 18.1 add-on installer: https://www.altera.com/downloads/fpga-development-tools/quartus-prime-lite-edition-design-software-version-18-1-windows). That is the tested pairing for this IP and device.
I hope this is helpful for you to continue with the simulation.
Ven
- Christophe10 days ago
Hi Ven,
I tried executing "do runtb.do" via modelsim starter edition 10.5b for Quartus 2018.1.
I got an error "Error: (vcom-13) Recompile sgate.sgate_pack because ieee.std_logic_1164 has changed."
And also "Error: stratixiigx_hssi_atoms.vhd(1402): Unknown expanded name."
I do not know how to return to a previous version of the library. So I think I will try to update my work and project now.
This ticket can be closed, but I will not mark this comment as solution as maybe others could have the problem.
Thank you for your responseBest Regards
- VenT_Altera3 days ago
Hi Christope,
Thank you for your update. Please try to recompile the Altera simulation libraries against your current ModelSim installation.
I will transition this thread to community support. If you have a new question, feel free to open a new thread to get support from Altera experts.
Ven
