How to handle tx_st_ready for Cyclone V PCIe
- 2 months ago
Hi corestar
I noticed the screenshot in your post appears to be from the older and obsolete user guide (Cyclone® V Hard IP for PCI Express* User Guide). While this document may still be accessible through internet searches, it has been removed from the official Altera documentation site, see this KDB: https://community.altera.com/kb/knowledge-base/why-is-the-cyclone%C2%AE-v-hard-ip-for-pci-express-user-guide-page-not-found/347580
To access the latest documentation, please use the following resources:- PCIe Support Center: https://www.altera.com/design/fpga-ip/pcie-support
For PCIe documentation, the best starting point is the PCIe Support Center. This page consolidates PCIe user guides across all supported device families. - Altera Documentation & Resources Center: https://docs.altera.com/
Since you are using the Avalon-ST interface, please refer to the Cyclone® V Avalon® Streaming (Avalon-ST) Interface for PCIe Solutions User Guide*. You can find the user guide link in the provided KDB, PCIe Support Center, and Altera Documentation & Resources Center.
I also noticed that the timing diagram shown in your screenshot (Figure 7-21) has been corrected in the latest user guide revision. The updated diagram provides a clearer description of the signal behavior.
Below the is the corrected timing diagram:
To answer your question on readyLatency:- readyLatency is not a user-selectable IP parameter in the Cyclone V PCIe IP Parameter Editor. Instead, it describes the effective handshake timing between the PCIe core and the application logic. The PCIe Hard IP drives tx_st_ready, while the application logic drives tx_st_valid and tx_st_data.
- The user guide states that when tx_st_ready, tx_st_valid, and tx_st_data are registered in the typical implementation style, Altera recommends a readyLatency of 2 cycles to facilitate timing closure; however, a 1-cycle response is also possible.
- In practice, this means:
- 2-cycle readyLatency is the recommended and easier case for timing closure
- 1-cycle readyLatency can reduce latency, but it requires a tighter ready-to-valid/data path in the user RTL and is therefore harder to meet timing.
Additionally, the Avalon-ST specification (user guide link: https://docs.altera.com/r/docs/683091/22.3/avalon-interface-specifications/synchronous-interface?tocId=LUasgm1svG8VSQd1UQY7Aw) states that source outputs toward the sink, including data, must be registered on the rising edge of the clock, which is why the registered 2-cycle implementation is considered the typical case.
I hope this answers your questions. Please let me know if any clarification is needed.
Ven Ting - PCIe Support Center: https://www.altera.com/design/fpga-ip/pcie-support
Hi corestar
Ven Ting
Hello VenT_Altera ,
Sorry for the late response; we're on Holiday here. I've implemented timing as per the diagrams and it seems to work, but I always like to understand things.
I think what was confusing me is the statement that the readyLatency is two clock cycles:
I think what they mean to say is the readyLatency is up to two clock cycles.
Is the following a valid way to look at things:
The PCI core always accepts data when tx_st_valid is high. However, it tx_st_ready goes low, you must deassert tx_st_valid within two clock clock cycles and not reassert until at least one clock cycle after tx_st_ready goes high again.
Dave
- VenT_Altera1 month ago
Hi corestar,
Thank you for the updates, and I apologize for the delayed response.
Yes, the tx_st_valid should reassert within 2 cycles after the tx_st_ready goes high again, assuming a readyLatency of 2 cycles.Thanks.
Ven Ting
