Serge93
2 months agoF-Tile PCIe Root Port 1x Gen3x4 - Configuration Read Type 0 receives no answer
Hello Support, I am using the Agilex 7F Dev Kit with F-Tile configured in Root Port Gen3x4. When I am doing a Configuration Write Type 0 to write the End Point BAR0 with FFFF_FFFFh, the end point se...
- 1 month ago
You may need to recheck your design if a given valid is not seen by the IP.
Here is how a F-Tile RP reads another FPGA's VID.
RongY_altera
Contributor
1 month agoThe F-Tile is RP so it's type1. The CfgWr0 to EP BAR0 with FFFF_FFFFh is for finding the BAR0 size, right? Once the EP BAR0 is enabled, the RP can read/write to that BAR.
Thus you need to set BDF on RP(type1), and enable BAR0 on EP(type0).
Rong
Serge93
1 month agoRong,
Can you translate your last sentence in bus access to the RP IP in order I understand what you mean.
Thank you.
Serge
