Serge93
2 months agoF-Tile PCIe Root Port 1x Gen3x4 - Configuration Read Type 0 receives no answer
Hello Support, I am using the Agilex 7F Dev Kit with F-Tile configured in Root Port Gen3x4. When I am doing a Configuration Write Type 0 to write the End Point BAR0 with FFFF_FFFFh, the end point se...
- 1 month ago
You may need to recheck your design if a given valid is not seen by the IP.
Here is how a F-Tile RP reads another FPGA's VID.
RongY_altera
Contributor
1 month agoI think something is mixed here. Most actions should be done to the type1 config register. But the mem space enable should be written to type0 command.
- Read @82h to get Link Rate and Link width
- Write 00h at @18h
- Read @18h to check previous Write
- Write 01h at @19h
- Read @19h to check previous Write
- Write 01h at @1Ah
- Read @1Ah to check previous Write
- Write 00h at @1Bh
- Read @1Bh to check previous Write
- Write 06h at @04h <------------------------to type0 command
- Read @04h to check previous Write
Rong
Serge93
1 month agoHello Rong,
All these accesses are done on the configuration space of the RP Pcie directly through the configuration bus.
There is no type 0 or type 1 concern to have.
Serge
