Serge93
3 months agoF-Tile PCIe Root Port 1x Gen3x4 - Configuration Read Type 0 receives no answer
Hello Support, I am using the Agilex 7F Dev Kit with F-Tile configured in Root Port Gen3x4. When I am doing a Configuration Write Type 0 to write the End Point BAR0 with FFFF_FFFFh, the end point se...
- 3 months ago
You may need to recheck your design if a given valid is not seen by the IP.
Here is how a F-Tile RP reads another FPGA's VID.
RongY_altera
Contributor
3 months agoHi Serge,
>>This doesn't look right. For a BAR test, I think you should use MWr and MRd.
Rong
Serge93
3 months agoHello Rong,
Nice to see you again.
BAR0 in address 10h, is in the Configuration Space not in the Memory Space, so you have to use a Configuration Access. I am using the same access with my Agilex7i-R-Tile board and it is working. So this is very strange it is not working on the Agilex-7F board.
Thanks for help.
Serge
