brian1211
3 years agoCXL type 3 example design increase to 128GB per channel?
What needs to change in the CXL type 3 example design to increase the Memory to 128GB per channel? I tried changing the emif IP to a DIMM, and updated the scripts to not define ENABLE_DDR_DBI_PINS....
brian1211
3 years ago@crclayton I think this error was actually simply a duplicate pin declaration, so same IP IO pin had 2 set_location_assignments to 2 different package pins. Hope that helps.
crclayton
3 years agoThank you!
