Questions about using Remote Update IP core
Hello, I'm using Remote Update IP core in my design. The device is cyclone 10LP, and the configuration device is EPCQ64A.
I set the boot address of the application image as 0x400_000 which is half of the address space of the flash device.
But when I was debugging my design, I found that, although the application image was loaded on the FPGA, the value of the boot address of this image I read was wrong.
I wonder if there's any detail I ignored? The parameters I set were as follows.
And the value I read is 0x1_000_000 which is wrong.
Thank you!
Apologize for the delay in response as this case was only routed to me today.
- I am assuming you have follow this design example, but having problem with the boot address?
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/ug/ug_altremote.pdf
2.Please let me know if my understanding is correct or not. If you are following the design example, do you check on the design example?
Aiman
- NurAiman_M_Intel
Aiman
- NurAiman_M_Intel
Any update fort this request? Else, I will proceed to close this case.
Aiman
