19 years agoquestion of io timing constraints of (r)gmii of the triple speed ethernet mac
hi, I have a question of io timing constraints of (r)gmii signals of Altera's triple speed ethernet MAC core. Within the tcl/sdc constraint file generated by megawizard, I cannot find the ...
19 years agohi,
We use marvell phy. I understand that there are detailed timing parameter in marvell spec. But I quite want to get the references of their IP from altera. I hope the IP should at least include simple example of pin assignment, timing constraints. regards,
