15 years agoQuestion about PCIe speed
I have been working on the chaining DMA example project for PCIe provided by Altera. I am a bit confused about what performance I should expect though. When sending 16.384 GBytes of data f...
14 years agoThank you for the responses!
I understand the whole thing a bit better now. By tweaking some parameters, I actually get a speed close to what you reported (multiplied by 8, since I am using 4 lanes and Gen2). There still is one problem though: I can get this speed when doing either a DMA read, or a DMA write. But I don't understand how to do both at the same time. I am using the chaining DMA example, and thus need to fill the descriptor table. I fill up the descriptors (endpoint address, root complex address, length of the data), then write the number of descriptors into the write header to launch a write, or the read header to launch a read. From what I understand, both the DMA write and the DMA read modules share the same descriptor table, so how can I trigger them at the same time? how do they know which descriptor is for which module? or is a local copy of the descriptor table generated after launching one of them, so that I can overwrite previous descriptors even before the operation is over?
