amolkumar's avatar
amolkumar
1 month ago
Queries on 46.6944 Gbps PAM4 F-Tile Configuration and Loopback Testing using Agilex7
Team,
Quartus: Quartus Prime Pro 26.1.0
I am currently working on an Agilex 7 F-Tile transceiver configuration for a 46.6944 Gbps PAM4 application. Please find my query (Read file) as attached and provide advise..
amolkumar
  • Hello,
    Please find the below snap shot from the user guide of F-Tile PMA/FEC Direct PHY IP user guide.
    The support of fgt_rx_signal_detect_lfps_port has been removed in the 25.1.1 release. Previously it was supported by Altera.
    The issue we are facing is that we are required to use this signal for our use case to detect the low frequency periodic signalling. Is there any way to enable this port in the latest version of Quartus F tile IP?
  • Hi,
    I would like to add a few points to this query. Amol and I are both working on this issue and would appreciate your guidance.
    I was able to achieve a clear BER result using an external loopback when the AC Coupling option was enabled in the F-Tile PMA IP.
    However, during testing with custom RTL-generated data patterns, I encountered an issue related to the Locked to Data status. My test consists of short bursts of data with the following sequence:
    IDLE → PREPARE → LEVEL1 → PRBS Data → IDLE
    IDLE: No data transmission for approximately 10 seconds.
    PREPARE: FFFF pattern transmitted continuously for a few cycles.
    LEVEL1: 3333CCCC3333CCCC pattern transmitted for a few cycles.
    PRBS Data: PRBS pattern transmitted for a longer duration. In this state, I am able to achieve Locked to Data.
    IDLE: Transmission stops, and the Locked to Data status is lost again.
    The main issue is that, after returning from the IDLE state, the receiver takes too long to achieve Locked to Data. Because of this, I am unable to reliably receive the short FFFF and 3333CCCC patterns at the beginning of the next burst.
    I have also tried transmitting the patterns for 65,536 cycles at 364.8 MHz using a 128-bit parallel interface, but the CDR still does not lock to data early enough for my application.
    Since the current configuration uses Auto Adaptation, I considered freezing the CDR/adaptation state after the PRBS Data phase. However, this appears to require Manual Adaptation, and my understanding is that FGT PAM4 does not support Manual Adaptation.
    I also tried enabling lock_to_ref, but it does not appear to resolve the issue in this configuration.
    Could you please advise if there is any supported mechanism in FGT PAM4 / BASIC mode to achieve either of the following:
    1. Faster CDR recovery/lock to data when a new short burst arrives after a long idle period, or
    2. Freezing/holding the CDR state after it has successfully locked to data, and keeping it frozen until explicitly deasserted.
    I noticed that the CDR Freeze functionality described in the documentation appears to be applicable only to GPON mode, whereas my configuration is BASIC mode with FGT PAM4 at approximately 46.7 Gbps.
    Our main objective is to reliably receive these short bursts of data, which is important for the implementation we are currently working on.
    Any guidance on the supported CDR configuration, registers, or other mechanisms that could help achieve this behavior would be greatly appreciated.
    Himanshu
    • CheepinC_altera's avatar
      CheepinC_altera
      Thank you for the additional details. Your observation that PRBS eventually achieves Locked to Data, while the short FFFF and 3333CCCC... patterns are not reliably captured after a long idle interval, is consistent with the CDR needing sufficient data transitions to reacquire lock. During the long idle interval, I believe the CDR has lost LTD mode. Thus, when the burst come, it is expected that the short FFFF and 3333CCCC patterns cannot be captured because the CDR is not in LTD yet.
      For FGT PAM4 in BASIC mode, we do not recommend treating lock_to_ref or fgt_rx_cdr_freeze as a supported way to preserve the previous lock-to-data/adaptation state:
      • lock_to_ref changes the CDR reference behavior and lock to the refclk; it is not a “hold the last lock-to-data state” function.
      • fgt_rx_cdr_freeze is documented for the GPON inactive-timeslot use case. We do not have a documented general-purpose BASIC-mode PAM4 mechanism that freezes the CDR state.
      The recommended workaround is to add a transition-rich preamble after every long idle period. For example:
      • Keep the lane electrically active if the application permits.
      • Transmit a known PRBS or other transition-rich training pattern first.
      • Wait for rx_is_lockedtodata to assert, or discard the RX data until it asserts.
      • Transmit the FFFF and 3333CCCC... patterns and then the payload
      Please let me know if there is any inquiry. Thank you.
      • Himanshu_Varia's avatar
        Himanshu_Varia
        Thanks for providing your guidance.
        I truly understand that first transmitting a rich training pattern followed by FFFF and 3333CCCC would work as the locked to data state would be there due to the PRBS transmitted first. But in our application, the first intended packets to be received are FFFF and 3333CCCC patterns and later on the training sequence is intended to be received. As the FFFF and 3333CCCC patterns are not enough for locking the data, we were planning to either hold the CDR state during lock state when PRBS is received or either use the lock to reference mode so that we can receive the data on the rx clock.
        However, none of the two options seems to work for FGT PAM4, am i correct ?
        Because in real time application, we are required to receive the FFFF and 3333CCCC pattern first for the initial training.
        Can i get to know how much time does it take to get the locked to data status? This would help us to know the number of FFFF and 3333CCCC pattern to be transmitted enough which could help us to observe that if we increase the number of times FFFF and 3333CCCC patterns, we are able to get the locked to data status or not.
        Himanshu
    CheepinC_altera
    Regarding the external loopback BER results, I apologize, but I was unable to locate the specific test results and configuration details that you are referring to.
    In general, the target BER requirement depends on your system design and the protocol specifications being used. Therefore, we recommend reviewing your system-level and protocol-level BER requirements to determine the appropriate target value.
    If additional link optimization is required, you may consider performing manual PMA tuning using the Transceiver Toolkit (XCVR Toolkit). For more information, please refer to the F-Tile Architecture and PMA and FEC Direct PHY IP User Guide, specifically the "Debugging F-Tile Transceiver Links" section, which provides guidance on transceiver link debugging and tuning.
    Please let us know if you have any further questions or require additional assistance.
    Thank you.
    CheepinC_altera
    Regarding your inquiry on the gray coding control, yes. For FGT, Gray coding is forced On in the PAM4 GUI but is explicitly disableable through register writes. Use read-modify-write access:
    TX: 0x47808[3] = 0
    RX: 0x47810[2] = 0
    You may refer to the F-Tile PMA and FEC Direct PHY IP Register Map for further details (https://docs.altera.com/v/u/resources/647401/f-tile-pma-and-fec-direct-phy-ip-register-map). Thank you.
    CheepinC_altera
    Regarding the 2D eye diagram inquiry, for your information, the Agilex 7 F-Tile Transceiver Toolkit does not support a 2D eye plot. It provides scalar measurements ie eye heights and widths. You might need to use oscilloscope for 2D eye diagram measurement as a workaround. Sorry for the inconvenience.
    CheepinC_altera
    As I understand it, you have several inquiries related to BER performance on the F-Tile Transceiver. Let me address them one by one.
    Regarding your observation that the external loopback shows a non-zero BER while the internal loopback reports zero BER, this is expected behavior. In internal loopback mode, the transmitted data is looped back to the receiver within the transceiver itself, bypassing the external channel. As a result, the signal is not exposed to any external signal integrity impairments such as channel loss, noise, crosstalk, or reflections.
    In contrast, external loopback exercises the complete signal path, including the PCB traces, connectors, cables, and other channel components. Therefore, any signal integrity degradation along the external path may contribute to bit errors and result in a non-zero BER.
    By the way, I was unable to locate the test design and Transceiver Toolkit results that you referenced. It is possible that I may have missed them. Could you please point me to the relevant files or share them again for review?
    Please let me know if you have any concerns or additional questions. Thank you.
  • amolkumar's avatar
    amolkumar
    Team,
    Please find design example and toolkit test results.
    Part: AGIB027R31B1E1VC
    Quartus Pro 26.1
    amol
      CheepinC_altera
      Hi amol,
      Thank you for filing this case and sharing the details. I appreciate your patience. Please allow me some time to review the information, and I’ll get back to you as soon as possible.
      amolkumar
