amolkumar
1 month agoQueries on 46.6944 Gbps PAM4 F-Tile Configuration and Loopback Testing using Agilex7
Team, Quartus: Quartus Prime Pro 26.1.0 I am currently working on an Agilex 7 F-Tile transceiver configuration for a 46.6944 Gbps PAM4 application. Please find my query (Read file) as attached and ...
CheepinC_altera
1 month agoHi,
Regarding your inquiry on the gray coding control, yes. For FGT, Gray coding is forced On in the PAM4 GUI but is explicitly disableable through register writes. Use read-modify-write access:
TX: 0x47808[3] = 0
RX: 0x47810[2] = 0
You may refer to the F-Tile PMA and FEC Direct PHY IP Register Map for further details (https://docs.altera.com/v/u/resources/647401/f-tile-pma-and-fec-direct-phy-ip-register-map). Thank you.
