Quartus Pro v21.1. Synthesis error of two independent instance of FFT
Yesterday I got temporary license for Quartus Prime Pro. And stucked right at the beginning of using Pro version. In the past I always used Standard version of quartus. Very simple test is not compiling by Pro version. Test project attached. Project contains just top file, and 2 qsys files of "FFT Intel FPGA IP". If use only one FFT - everything is ok. But if add second one - fail. Compilation fails during "Synthesis". Standard version of quartus compiles as expected without problems. The same situation with NCO.
I tried to investigate errors and found out, that quaruts pro generates tmp-clearbox directory with *.tdf files. I guess that some of this files are used by fft. Inside some of this files full path to hex files:
INIT_FILE="fft_a/altera_fft_ii_191/synth/fft_a_altera_fft_ii_191_glumlpq_3n256cos.hex",
some files contains just name of hex wihtout path:
INIT_FILE="fft_b_altera_fft_ii_191_tdfvdzi_2n512sin.hex".
Screenshot of quartus report in attached jpg file. Is it a bug of quartus or I do something wrong?
Regards, Pavel
Hi Pavel,
Here's a KDB that can help you with your issue: https://www.intel.com/content/altera-www/global/en_us/index/support/support-resources/knowledge-base/embedded/2019/can-t-find-memory-initialization-file-or-hexadecimal--intel-form.html
Let me know if this helps,
Nurina
P/S: Feel free to give Kudos to any helpful comments.
- Nurina
Hi Pavel,
Nurina
- vdpavel
Hi Nurina
That exactly what I need. Thank you
Pavel
- Nurina
Hi Pavel,
Nurina
PS: If there's any helpful answer given by the community or Intel Support, feel free to give Kudos.
