bjwinter
4 years agoQuartus Prime v18.1 : Arria 10 DDR4 Controller & PHY
This error appears when I attempt to Synthesize a design containing a DDR4 Controller and PHY combination in an Arria 10 target.
Error (129029): Input port RZQIN on atom "ddr4:u_ddr4|ddr4_altera_em...
AdzimZM_Altera
4 years agoHi Bradley,
You need to make a connection in your top level design for the instances.
- OCT
- Reset
The EMIF_pll_ref_clk cannot be hooked up to internal PLL pin.
It's must be connected to external pin.
There are several dq pins that are not fit in the design.
So I let the Quartus to Auto Fit the signals pin location.
I will share the design that I've edited.
I hope it's working just like you wish.
Adzim
