Quartus Prime Pro 22.4 F-tile error: Error(21842): Support logic cannot be generated because IP
I tried to set the F-tile:
- FHT
- Number of PMA lanes: 4
- System PLL
- PAM4
- PMA width: 128
- Disable RS-FEC
I use the example "FHT PAM4 4 400G 4 PMA lanes RSFEC 544/514" in F-tile PMA/FEC Direct PHY Intel FPGA IP. But, I want to disable the RS-FEC. I only click the "Enable RS-FEC", this shuts down the RS-FEC. And I open the example_design -> rtl -> param_desines1.iv, comment the "`define RSFEC_TESTWRAP 1". Then, Quartus 22.4 starts compiling.
At the Logic generation, I get errors.
Error (21842): Support logic cannot be generated because IP components used in the design have conflicting settings Error (21843): Conflict 0 ---------------------------------------------------------------- Error (21843): Rule: gdra_gdr_barak_quad::bk_rxbit_rollover_lane3_rule @ gdr.z1577a.u_barak_quad Error (21843): ((gdr.z1577a.u_barak_quad.bk_rxbit_rollover_lane3 -> u0|example|dphy_hip_inst|persystem[0].perxcvr[0].fht.x_bb_f_bk.bk_rxbit_rollover)>=(gdr.z1577a.u_barak_quad.bk_rx_lat_bit_for_async_lane3 -> u0|example|dphy_hip_inst|persystem[0].perxcvr[0].fht.x_bb_f_bk.bk_rx_lat_bit_for_async)) || gdr.z1577a.u_barak_quad.powerdown_mode == TRUE Error (21843): Rule: gdra_gdr_barak_quad::gdr_barak_quad_avmm_cfgcsr_power_down_rule @ gdr.z1577a.u_barak_quad Error (21843): gdr.z1577a.u_barak_quad.powerdown_mode == FALSE || (gdr.z1577a.u_barak_quad.refclk1_freq -> u1|systemclk|x_hip|gen_fht_bb_[0].enabled.refclk_inst.freq) == 1 Error (21843): Input variables: Error (21843): user.bb_f_bk[0] -> u0|example|dphy_hip_inst|persystem[0].perxcvr[0].fht.x_bb_f_bk Error (21843): bk_rx_lat_bit_for_async == 5248 Error (21843): bk_rxbit_rollover == 5152 Error (21843): is_used == TRUE Error (21843): location == BK3 Error (21843): user.bb_f_bk_refclk[0] -> u1|systemclk|x_hip|gen_fht_bb_[0].enabled.refclk_inst Error (21843): freq == 156250000 Error (21843): is_used == TRUE Error (21843): location == BK_REFCLK1 Error (21843): Conflict 1 ---------------------------------------------------------------- Error (21843): Rule: gdra_gdr_barak_quad::bk_rxbit_rollover_lane3_rule @ gdr.z1577a.u_barak_quad Error (21843): ((gdr.z1577a.u_barak_quad.bk_rxbit_rollover_lane3 -> u0|example|dphy_hip_inst|persystem[0].perxcvr[0].fht.x_bb_f_bk.bk_rxbit_rollover)>=(gdr.z1577a.u_barak_quad.bk_rx_lat_bit_for_async_lane3 -> u0|example|dphy_hip_inst|persystem[0].perxcvr[0].fht.x_bb_f_bk.bk_rx_lat_bit_for_async)) || gdr.z1577a.u_barak_quad.powerdown_mode == TRUE Error (21843): Rule: gdra_gdr_barak_quad::gdr_barak_quad_avmm_cfgcsr_power_down_rule @ gdr.z1577a.u_barak_quad Error (21843): gdr.z1577a.u_barak_quad.powerdown_mode == FALSE || (gdr.z1577a.u_barak_quad.bk_rxbit_rollover_lane3 -> u0|example|dphy_hip_inst|persystem[0].perxcvr[0].fht.x_bb_f_bk.bk_rxbit_rollover) == 0 Error (21843): Input variables: Error (21843): user.bb_f_bk[0] -> u0|example|dphy_hip_inst|persystem[0].perxcvr[0].fht.x_bb_f_bk Error (21843): bk_rx_lat_bit_for_async == 5248 Error (21843): bk_rxbit_rollover == 5152 Error (21843): is_used == TRUE Error (21843): location == BK3 ......
Please help me check the source of the problem, is it a bug?
- Kshitij_Intel
If you select any of the four available Example Design Options, but change the F-Tile PMA/FEC Direct PHY Intel® FPGA IP settings in the GUI thereafter, the example design generated does not follow the changed settings for the F-Tile PMA/FEC Direct PHY Intel® FPGA IP. The example design generation only takes the Example Design Options listed in Example Design Generation Options. Any other changes that you make to the F-Tile PMA/FEC Direct PHY Intel® FPGA IP settings are not applied during example design generation.
Clicking Generate Example Design completes the IP Generation and Support-logic Generation stages of the Compiler.
For more info please refer to the below link.
Hope this will resolve your issue.
Thank you
Kshitij Goel
- Kshitij_Intel
As we do not receive any response from you on the previous answer that we have provided. Please login to ‘https://supporttickets.intel.com’, view details of the desire request, and post a response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you on your follow-up questions.
Thank you
Kshitij Goel
