Dongwei939
3 years agoQuartus Prime Pro 22.4 F-tile error: Error(21842): Support logic cannot be generated because IP
I tried to set the F-tile:
FHT
Number of PMA lanes: 4
System PLL
PAM4
PMA width: 128
Disable RS-FEC
I use the example "FHT PAM4 4 400G 4 PMA lanes RSFEC 544/514" in F-tile PMA/FEC ...
Kshitij_Intel
3 years agoHi,
If you select any of the four available Example Design Options, but change the F-Tile PMA/FEC Direct PHY Intel® FPGA IP settings in the GUI thereafter, the example design generated does not follow the changed settings for the F-Tile PMA/FEC Direct PHY Intel® FPGA IP. The example design generation only takes the Example Design Options listed in Example Design Generation Options. Any other changes that you make to the F-Tile PMA/FEC Direct PHY Intel® FPGA IP settings are not applied during example design generation.
Clicking Generate Example Design completes the IP Generation and Support-logic Generation stages of the Compiler.
For more info please refer to the below link.
Hope this will resolve your issue.
Thank you
Kshitij Goel
