Quartus_Lite_22_1_not_generating_time_limit_sof
I'm resurrecting a Cyclone IV project from a few years back. The last time I compiled and ran it was with version 20.1. Within the last week I updated to version 22.1. I am and have been running the Linux versions of Quartus Lite.
I recreated the project in the latest version in case there were incompatibilities between versions. I would like to generate the BSP so that I can download some C-code in Eclipse in order to communicate with my PC, but I am running into a problem.
For IP I am using a Nios II/e and a PLL. Everything compiles fine and a standard .sof is generated, but the time_limit.sof is not generated.
When I look at the 'IP Cores Summary' in 'Analysis & Synthesis' I see 6 instances of Signal Tap which I assume, because it indicates it is licensed, is the cause of Quartus Lite not generating the time_limit.sof.
I have verified that Settings/Signal Tap Logic Analyzer/ DOES NOT have 'Enable Signal Tap Logic Analyzer' checked. Any ideas would be appreciated.
- RichardT_altera
If the IP has been licensed (not on evaluation license), then the Quartus will generated .sof file.
Why use Time-Limited Programming File when you have the standard .sof file that works without a time limitation?
You can check your IP license status at the assembly report and compare the differences between two projects.
It should show you a list of all the cores that you used that require a license. It should tell you exactly which core you used that made your sof file time limited.
Richard Tan
- sstrell
Signal Tap is not a licensed IP so that wouldn't prevent you from getting a .sof file, time-limited or otherwise. But it doesn't make sense that Signal Tap is disabled and yet you are seeing it. Are you confusing Signal Tap with something like "sld_hub"? That's just the JTAG interface for debugging.
I use Pro so the setting may be in a different location, but check that you have .sof file generation (the Assembler) enabled or try running the Assembler manually from the Processing menu to see if it spits out a file. Also check Assignments -> Device -> Device and Pin Options and Assignments -> Settings -> Assembler.
- FPGA70
It has been a few years since I ran licensed copies of Vivado or Quartus at work. These days I run the Lite version of Quartus which works great for my hobby stuff.
You are right that there was a difference between the project I ran some years back and the one I am trying to get to run under 22.1. I used Nios II/f then, but I found literature that indicated it was not available for this latest version of Quartus Lite so I am running Nios II/e which works fine for my purposes. In the past I would see a time-limit.sof generated, but maybe Nios II/e does not do that. Selecting the Nios II/e compiles with no errors.
The problem I am running into now is that when I try to generate a "Neos II Application and BSP from Template" with Eclipse, it generates 3 errors during Build even when using the standard "hello world small" file. Guess it is time to go over to the Eclipse forum and bug them.
Thanks for your help
- RichardT_altera
I believe that Nios II/e is free to use so that could be why there is no time-limited .sof generated this time.
Please do bug the Nios expert for your follow-up question.
; ) Anyhow, I’m glad that your question has been addressed, I now transition this thread to community support.
Thank you.
Richard Tan
- sstrell
I guess there's a misunderstanding here. Are you saying you get *no* .sof file or that you do get a .sof file but you expect it to be time-limited?
If you get no .sof file at all, then follow what I said above. If you are saying you get a .sof but it is not time-limited, that's because II/e does not require a license (as was mentioned) while II/f (which does still exist) does require a license. It sounds like this is what you mean.
- FPGA70
Thank you for your response. After I build the project I get a .sof file, but I expected the time-limited version.Speculation: I had used the Nios II/f in with an earlier version of Quartus Lite (this might have been before Altera was bought by Intel) so I am assuming that Quartus Lite used to generate a time-limited.sof (good for 1 hour).Now it is not possible to use the II/f with Lite and generate the time-limited.sof. This is okay because I am not using the resources supplied beyond the II/e core. As I mentioned, this is just a hobby now that I am retired and playing mostly with ham radio and trivial projects compared to years back.You can close this item, but I do have a question for you. I downloaded Eclipse Mars.2 Release (4.5.2) but it fails when I try to create the Nios II BSP. I tried a generic 'Hello World' code with the Nios II BSP, but I still get the same failure report (see attachment). Is this something for the Intel forum or should I chat with the Eclipse organization? Searching both sites, I did not find what I thought was a similar problem.Last note: Just before upgrading the Quartus and Eclipse applications, I upgraded to Linux MInt 21.1.Thanks again. I appreciate the cycles you have spent on this ticket.Jim
