FPGA70
3 years agoQuartus_Lite_22_1_not_generating_time_limit_sof
I'm resurrecting a Cyclone IV project from a few years back. The last time I compiled and ran it was with version 20.1. Within the last week I updated to version 22.1. I am and have been running t...
RichardT_altera
3 years agoIf the IP has been licensed (not on evaluation license), then the Quartus will generated .sof file.
Why use Time-Limited Programming File when you have the standard .sof file that works without a time limitation?
You can check your IP license status at the assembly report and compare the differences between two projects.
It should show you a list of all the cores that you used that require a license. It should tell you exactly which core you used that made your sof file time limited.
Richard Tan
