14 years agoQuartus II Web Edition and Altera IP
Hello, I am using Quartus II Web Edition version 11.1sp1, when I try to use Altera IP I get an error during the compile phase. Error (204012): Can't generate netlist output files because the...
9 years agoHi,
you should follow the same steps as above. If you want to run a simulation, it is advice to run it directly from ModelSim rather using the NativeLink feature. How to run a simulation in ModelSim is described online on various pages. You can find even YouTube videos explaining the needed steps. If you have problems running ModelSim you should open a new thread regarding ModelSim. You opened a 4 years old threat again. Cheers, fade
