Quartus 26.1.1: GTS AXI Streaming PCIe Reset Output Connection Error
Hi JV90,
The error I see after upgrading a GTS AXI Streaming PCIe IP design (I use PIO design example in my case) from Quartus Prime Pro 25.1.1 to 26.1.1 is on the PIO IP, not worded exactly as yours:
Error: pcie_ed.pio0.pio_pin_perst_n: pio0.pio_pin_perst_n must be connected to a reset source
In 26.1.1, the PIO design example reset controller uses PERST# to decide a cold reset. The PIO IP therefore adds a reset input, pio_pin_perst_n. Platform Designer requires every reset input to have a source, so connect pio_pin_perst_n to the GTS AXI Streaming IP output p0_pin_perst_n.
That connection is not required in the 25.1.1 PIO example, which is why the same design generates there with p0_pin_perst_n left open.
Ven
Hi JV90
May I know if you have any updates?
Ven
