Quartus 19.1 Standard on Windows and Stratix IV Hard Pci-Express missing file
During the generation of my system I get this error:
Error: altgx_internal: error copying "C:/intelfpga/19.1/quartus/../ip/altera/ip_compiler_for_pci_express/lib/altpcie_serdes_4sgx_x4d_gen2_08p.v": no such file or directory
while executing
"file copy -force $source_file $outdir/$output_file"
(procedure "my_generation_callback" line 73)
invoked from within
I checked and the folder C:\intelFPGA\19.1\ip\altera\ip_compiler_for_pci_express is missing from the installation, do you know how to solve this problem?
Thank you,
Leonardo
- SengKok_L_Intel
Hi Leonardo,
Yes, I replicated the same problem in v19.1std and already reported this matter to the Intel PSG engineering team to fix it.
Besides, I have also tested in v18.1std, the same problem does not happen, and probably you can use v18.1std as the temporary workaround.
Regards -SK
- ltazz1
I tried to copy that folder from 18.1 and seem to work in 19.1, anyway thank you and keep us up to date when a fix come out
Leonardo
- ltazz1
Another strange thing of the altera_pcie_hard_ip with stratix iv and v19.1std, it's impossible to use PCI-E Gen2 x8, in Platform Designer (ex QSys) I get the following message when setting parameters..
Error: system.pcie.pcie_internal_hip: Stratix IV GX and Arria II GZ Phy do not support Gen2 x8
- SengKok_L_Intel
Yes, that could be one of the possible workarounds.
As per the user guide, table 1-2, Gen2 x8 is not supported.
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/ug/ug_pci_express.pdf
When you configure it as Gen2x8 in v18.1, you will also notice the same error.
Regards -SK
- ltazz1
These statements then are not clear if Gen2 x8 is not supported:
Stratix IV GX devices with speed grades C2/C2x/C3/I3 should be used to support PCIe Gen2 x1/x4/x8.
https://www.intel.co.uk/content/www/uk/en/products/programmable/fpga/stratix-iv.html
The Stratix® IV GX FPGA is fully compliant with PCI-SIG* for PCI Express* (PCIe*) Gen1 and Gen2 (x1, x4, and x8) and is on the PCI-SIG* integrators list
Leonardo
- SengKok_L_Intel
What you are using is Avalon-MM Interface, and it only supports up to Gen2x4 for the Stratix IV device. For Gen2X8 support, it uses the Avalon-ST interface, however, the PCIe Avalon-ST IP GUI is no longer available in v19.3. Table 1-5 in the link below show the difference between the Avalon ST and Avalon MM for Stratix IV device and others:
Regards -SK
- ltazz1
Thank you for the clarification.
I am reverting back on Q18.1 to use PCIE, just in case, to avoid any problem.
I was trying to compile some example of the DE4 dev board but internal timing of the PCI IP are failing:
pcie|pcie_internal_hip|stratix_iv.stratixiv_hssi_pcie_hip|coreclkout setup slack -1.194
Is something that can be ignored?
- SengKok_L_Intel
You probably need to check if the failing location is from the two different clock sources. If no, you can't simply ignore it.
Regards -SK
- ltazz1
Hello, this is the main timing failure
Slack -0.690
From Node system:u_sys|system_pcie:pcie|altpcie_hip_pipen1b_qsys:pcie_internal_hip|dl_ltssm[4]
To Node system:u_sys|system_pcie:pcie|altpcie_hip_pipen1b_qsys:pcie_internal_hip|altpciexpav_stif_app:avalon_stream_hip_qsys.avalon_bridge|altpciexpav_stif_control_register:cntrl_reg|altpciexpav_stif_cr_avalon:i_avalon|CraReadData_o[4]
Launch clock u_sys|pcie|pcie_internal_hip|stratix_iv.stratixiv_hssi_pcie_hip|coreclkout
Latch clock u_sys|pcie|pcie_internal_hip|stratix_iv.stratixiv_hssi_pcie_hip|coreclkout
Relationship 4.000
Clock skew -0.311
Data delay 4.296
I was thinking that the timing of the hard ip were fixed and guarantee, this is the chip planner picture
Leonardo
- SengKok_L_Intel
I don't see this timing violation when I compile the Strativ IV PCIe IP in v18.1. If more help is needed, you may attach a simple design that can replicate this violation here, so that I can look into it.
Regards -SK
