14 years ago
Qsys throws error while generating DDR2 Uniphy
I am getting the following error while generating the Qsys system in Linux.
Error: s0: add_fileset_file: No such file /tmp/alt5543_8846100032461293346.dir/0025_s0_gen/qsys/nios_dma_dram_mem_if_ddr2_emif_0_s0_sequencer_mem.hex
while executing
"add_fileset_file $file_name [::alt_mem_if::util::hwtcl_utils::get_file_type $file_name 0] PATH $generated_file"
("foreach" body line 4)
invoked from within
"foreach generated_file [alt_mem_if::gen::uniphy_gen::generate_sequencer_files $name "DDR2" $tmpdir QUARTUS_SYNTH] {
set file_name [file tail $genera..."
(procedure "generate_synth" line 8)
invoked from within
"generate_synth nios_dma_dram_mem_if_ddr2_emif_0_s0"
The design contains a DDR, Nios processor, jtag uart, sys id and dma controller.
I am using Quartus 12.0
I am invoking Generate from Qsys with root permissions.
Please find the Qsys file attached for your reference (rename attached file to .qsys to open in Qsys)
Appreciate your feedback
Deepak
    --- Quote Start ---
    I am getting the following error while generating the Qsys system in Linux...
    --- Quote End ---
    Unfortunately I don't work with QII under Linux.
    I've generated your provided Qsys system under Windows Q12.0 64-Bit without any errors.
    I've attached the complete project with all generated files.
    Maybe you'll have to remove all of your intermediate files?
    I do that very often...
    Thank you for the generated system.
    I tried cleaning up the /tmp directory. Unfortunately, that didnt help.
    My guess is that this is probably a Qsys linux bug ?
    Deepak
    FWIW, I experienced same issue with Altera 12.1 on Ubuntu 12.04.1
    edit altera/13.0sp1/nios2eds/bin/elf2hex, change first line to# !/bin/bash
